Discussion topic: How can i add itvx to my sky q ??
Message posted on 01 Jun 2023 06:45 PM
Just had SkyQ installed and realised I'm missing ITVX and Channels 4&5...how can I add those apps please??
Message posted on 01 Jun 2023 07:01 PM
Re: How can i add itvx to my sky q ??
Hi @Steven+5757
First make sure that your Q box is on the latest Software.
https://www.sky.com/help/articles/updating-sky-box-software-sky-q
Message posted on 01 Jun 2023 07:03 PM
hi @Steven+5757
Please see this link for updating the Software & Apps
The latest software is Q220 but I think it has not 100% been rolled to every box so there is a possibility it will be Q210 which should be OK
Please note you should get ITV X but ALL4 & My5 are not available on SKY Q
Message posted on 01 Jun 2023 08:06 PM
Thank you...I definitely have new version of software installed but still no ITVX...after updating...I'll call Sky over weekend to see what they say....
Message posted on 01 Jun 2023 08:08 PM
Hi @Steven+5757
Did you try a box reboot
Message posted on 01 Jun 2023 08:09 PM
did you also go through the step to initiate a refresh of the Apps ?
Message posted on 01 Jun 2023 09:54 PM
Thanks for replying...as skyq system is new to me....how do I refresh the apps?
Tia
Message posted on 01 Jun 2023 10:02 PM
Tia
Hi @Steven+5757
Have you tried refreshing the Apps in the Hidden menu.
Select Apps
then highlight Refresh all Apps on this box.
You'll see a message that says, 'Your apps are being refreshed'. This will stay on screen until you press Dismiss to return to normal viewing
It’s recommended waiting at least 5 minutes before doing so.
Refresh Apps can take up to 24 hrs to complete .
Message posted on 01 Jun 2023 10:15 PM
Tia
@oldfella has replied but it was all in the link I gave
Message posted on 01 Jun 2023 10:19 PM
Thank you...apps refreshed and I have itvx....thank you
