Discussion topic: Recordings unavailabke
Message posted on 12 Sep 2024 08:14 PM
Recordings are current unavailabke and have been for 3 days
Message posted on 12 Sep 2024 08:19 PM
Re: Recordings unavailabke
Hi @JeanetteR62
If you also cannot make new recordings you may have a Hard Drive issue.
https://www.sky.com/help/articles/sky-q-hard-disk-error-messages
Also if the box you are replacing is a 2TB there are two versions of power supply. One has a standard C7 (figure of eight) power lead socket in the back of the Q box. The other has a separate power supply. Although this still has the C7 power lead into the power supply there is a multi pin Din power socket in the Q box for connecting the power supply. Make sure that the replacement box has the power supply included if the Q box has the orange coded multi pin din socket in the back of the Q box. See below.
Message posted on 12 Sep 2024 08:29 PM
Your duplicate thread has been removed as you've had a reply on this one.
