Discussion topic: Recordings saying....please wait and can't access
This message was authored by: Lisa+T
Anyone experienced this and have you fixed it?
Re: Recordings saying....please wait and can't access
Hi @Lisa+T
Can you make new Recordings or do you get a Hard drives message.
If you get a message check the following link.
https://www.sky.com/help/articles/sky-q-hard-disk-error-messages#:~:text=Press%20the%20Home%20button....
Avatar for Lisa+T
@oldfellajust checked and I get the hard drive message. Thanks for the link but it says I will lose all my recordings...is there any solution to this?
thanks
thanks
Afraid not @Lisa+T
Any Buy and keep from Sky Store will be retained but all your recordings are lost.
Avatar for Lisa+T
Thanks for your help...done the reset and it's worked
