Discussion topic: Recordings on Sky Q
This message was authored by: MichaelJ22
Recordings on Sky Q
Tim trying to play a recording on my Sky Q box but every recording says "this programme is no longer available"
If I try to set a recording I get error message "this programme cannot be recorded"
Re: Recordings on Sky Q
Hi @MichaelJ22
Have you tried rebooting your Q box?
If you still have issues and you also cannot make new recordings then work through the following link
https://www.sky.com/help/articles/sky-q-hard-disk-error-messages
Also if the box you are replacing is a 2TB there are two versions of power supply. One has a standard C7 (figure of eight) power lead socket in the back of the Q box. The other has a separate power supply. Although this still has the C7 power lead into the power supply there is a multi pin Din power socket in the Q box for connecting the power supply. Make sure that the replacement box has the power supply included if the Q box has the orange coded multi pin din socket in the back of the Q box.
Avatar for MichaelJ22
Thanks for the info. I've done the reset, power off etc multiple times. Sometimes it comes back and I can play recordings other times I can but usually if I can play/set recordings that only lasts for a couple days at most before it goes again.
This message was authored by: TonyG5
Hello, just to tick off one reason that would cause your Sky Q box to behave this way:
Go into ‘Recordings’ on the Sky Q box and confirm you have sufficient space left on the hard disk.
In general, you need to keep the used space of the Sky Q hard disk below 90%, otherwise the box will slow down and potentially have the issues that you are describing.
This message was authored by: Invisiblename
Hmmm, not sure you are correct, the Sky Q box has built-in drive management whereby it will overwrite the oldest recordings if it becomes full (and "full" would mean a hell of a lot of recordings!)
I am just another Sky customer!
Thanks! I always like to learn new things: Now I understand your point about disk space management.
Hard drive is done for. You likely need a new box.
Thanks, I had already checked and it is at 23% full
