Discussion topic: Recordings on Sky Q and Mini Box keeps saying connection problem
This message was authored by: David309207
I have recently been getting the following message when watching on my sky mini box and SKY Q box "you can't currently watch TV as there's an issue with the connection between this mini box and your sky q box". There is no particular time of day this happens but it happens every day at some point. When it happens, it will go off every few minutes and this can last for several minutes or several hours. Sometimes it goes off and comes straight back on but other times it will be off for several minutes. This is just ongoing now
This message was authored by Wallace6
This message was authored by Wallace62This messaI have recently been getting the following message when watching on my sky mini box "you can't currently watch TV as there's an issue with the connection between this mini box and your sky q box". There is no particular time of day this happens but it happens every day at some point. When it happens, it will go off every few minutes and this can last for several minutes or several hours. Sometimes it goes off and comes straight back on but other times it will be off for several minutes
Re: Recordings on Sky Q and Mini Box keeps saying connection problem
@David309207 Have you tried rebooting your main Q box ie
then
reboot your mini box
LG 49SJ 810 V UHD TV
Google Pixel 10 Pro XL mobile
Avatar for David309207
Level 0 icon
Yes thank you, I have ended up doing a factory reset and re paired my remote. Seems to be ok now but time will tell.
