Discussion topic: Recordings not working
Message posted on 04 Aug 2026 01:54 PM
Recordings not working - flags up hard disk drive not working
Message posted on 04 Aug 2026 02:02 PM
Re: Recordings not working
@Charlotteamelia
It’s always worth starting with a reboot of the main Sky Q box, then once that’s back up and running do the same with any mini boxes if applicable -
~ press the 🏠 button
Allow 5-10 minutes before things hopefully revert back to normal
If not, try following this link. It should lead to a replacement box if needed https://www.sky.com/help/articles/sky-q-hard-drive-errors
If you do need a new box remember to remove the viewing card from the faulty box before it disappears into the back of the couriers van and accept any new power cable DPD deliver with the replacement box in case it's different to the one you have.
