Discussion topic: Hisense 55A6KTUK TV PAIRING TO SKY Q REMOTE
Message posted on 15 Jun 2024 06:58 PM
Had issue pairing Sky-Q remote to Hisense 55 inch. New tv, used sky suggested code for Hisense
Tried other codes and found that that worked
Try 0206
Hope this helps
Message posted on 15 Jun 2024 07:22 PM
Re: Hisense 55A6KTUK TV PAIRING TO SKY Q REMOTE
Try 0206
Hope this helps
Mmm.
Sky Q Bluetooth remotes to not use codes @Andrew35351
You specify Brand and model in the pairing setup.
Message posted on 15 Jun 2024 09:51 PM
Meant it to read tried codes suggested by sky for Hisense tv's(Predictive texting rubbish),WHICH DID NOT WORK for my particular model but went through lots of other models codes and found this number worked(0206)
Just trying to give some positive feedback to help anybody who may be having the same problem.
Message posted on 28 Nov 2024 12:25 AM
- Works for me thanks so much was on hisense 75e7kqtuk
Message posted on 17 Feb 2025 07:30 PM
Thank you kindly!!! It worked well on Hisense 58E7NQTUK. I tried all the suggested codes from the SkyQ box, but none of them worked. This one did the magic :)))
Message posted on 15 Jul 2025 05:28 PM
Works for me using model 32E4NTUK. Thanks
