Discussion topic: Recordings not working, shows a blue screen
This message was authored by: dawnique
I set my q box to record but it never plays, just a blue screen. I then try to download it from sky witness and it just says sorry no longer available but it only screened 24 hours ago. Any advice?
Re: Recordings not working, shows a blue screen
Hi @dawnique
Avatar for dawnique
Thank you
