2
This discussion topic has been answered Discussion topic: Recordings not grouping together
This message was authored by: Ann-Marie37
Noticed the last couple of weeks that my recordings aren't grouping together anymore. They are all separate recordings which is really annoying. Is this SKY or can it be reset?
This message was authored by: MightyQuinn Answer
Re: Recordings not grouping together
Hi @Ann-Marie37   Yes a common problem over the last 10 years. Normally a router reboot (DNS refresh) followed by the Sky Q box power reboot sorts it. But don't expect it to correct it retrospectively.
Avatar for Ann-Marie37
Thank you we will give your suggestions a try.
