Discussion topic: Hard Drive reset stalled
This message was authored by: Karen+A+Masson
When I switched on sky Q this morning there was a hard disk error message with a QR code.
I followed the instructions and performed a hard disk reset.  After making some whirring noises every so often it is now stuck on a screen with a message that says 'you will be ready to go in a couple of minutes'.
I've tried virtual assistant for next steps but it keeps asking me to sign up.
Re: Hard Drive reset stalled
Hi @Karen+A+Masson
https://www.sky.com/help/articles/sky-q-box-wont-turn-on
Also if the box you are replacing is a 2TB there are two versions of power supply. One has a standard C7 (figure of eight) power lead socket in the back of the Q box. The other has a separate power supply. Although this still has the C7 power lead into the power supply there is a multi pin Din power socket in the Q box for connecting the power supply. Make sure that the replacement box has the power supply included if the Q box has the orange coded multi pin din socket in the back of the Q box. See below.
