Discussion topic: Recordings not coming up on mini boxes
Message posted on 09 Jul 2025 04:40 PM
On mini boxes my recordings are not coming up, just says please wait. I also can not download. I have 4 mini boxes. Please help ?
Message posted on 09 Jul 2025 05:47 PM
Re: Recordings not coming up on mini boxes
First thing to try is a full restart (power supply removed and replaced) of the main Q box.
Message posted on 10 Jul 2025 08:27 PM
This doesn't work have tried it a few times?
Message posted on 10 Jul 2025 09:33 PM - last edited: 10 Jul 2025 09:35 PM
Hi @Ollie48
Complete the following.
Reboot the minis as above.
If you are on Sky Broadband and the Router is nearer to the mini than the main box then you can try pressing WPS on the router instead of the main Q box. If you do this make sure you press the Sky router WPS button and not the router reset button. If you have the new Sky Max router then you need to connect the WPS to the main Q box.
If you get the first mini connected then for other minis use WPS on the nearest Q device (main Q box or Sky Router (not Sky Max) if on Sky Broadband or previously connected mini).
Message posted on 11 Jul 2025 07:18 AM
@Ollie48 wrote:This doesn't work have tried it a few times?
Are you sure the recording you're trying to watch is not in UHD? The mini box can't play UHD recordings
Message posted on 11 Jul 2025 10:26 AM
None of the recordings come up on mini boxes and does not let me down load. When. I try to access it just says please wait and nothing ever comes up
Message posted on 17 Feb 2026 11:12 AM
This is happening to me, I've rebooted all of my boxes including main sky q box. I've also reset network settings but still facing this issue
Message posted on 17 Feb 2026 07:17 PM
@gshoker+3 wrote:This is happening to me, I've rebooted all of my boxes including main sky q box. I've also reset network settings but still facing this issue
Same question as above, are you sure the recordings on your main box are not UHD?
Message posted on 17 Feb 2026 07:21 PM
Yep. These are regular non uhd recordings. Sky Go app picks up the recordings but none of my mini boxes do, just get the 'Please wait' message. Have an engineer visit booked as Tech Support couldn't work it out.
Message posted on 17 Feb 2026 08:17 PM
@gshoker+3 Have you tried rebooting your main Q box ie
then
rebooting the mini boxes
LG 49SJ 810 V UHD TV
Google Pixel 10 Pro XL mobile
Message posted on 17 Feb 2026 08:18 PM
Yeah tried this but still didn't work.
Message posted on 18 Feb 2026 07:44 AM
@gshoker+3 wrote:Yeah tried this but still didn't work.
If the engineer figures out what it is, would you mind posting back in here? Really weird problem and may help others who run into it in future.
Message posted on 22 Feb 2026 10:02 AM
I too am having problem getting recordings to mini box are there many people in this situation in February
