Discussion topic: Recordings disappeared
This message was authored by: Paddya
Hi all,
I've just come back from holiday and noticed that a whole heap of recordings have disappeared from our box. Some are buy and keep movies but also quite a few series. There doesn't seem to be any pattern with how it's done it because we have a 2021 programme still on there but lots of 2022 gone.
I've rebooted and also checked in deleted items but nothing.
Re: Recordings disappeared
@Paddya wrote:
Hi all,
@Paddya any buy& keep programmes can be downloaded to your box again.
If any of the series were downloaded the rights Sky have/had for them may have ended in which case they will have been deleted from your box
LG 49SJ 810 V UHD TV
Google Pixel 10 Pro XL mobile
Avatar for Paddya
Level 2 icon
@Paddya wrote:
Hi all,
It was all recorded items. Just odd that it's kept an item from 2021 but remove recordings from 2022
@Paddya wrote:
@Paddya wrote:
Hi all,
@Paddya if Sky still hold the rights for the programme from 2021 then it will not have been removed
Avatar for Paddya
Level 2 icon
Ok thanks although not convinced that's the reason. I know there where some BBC, Channel 5 and Discovery programmes on there to name a few.
Spoken to Sky and they are sending a recording specialist around on Thursday although not sure what they'll be able to do
