Discussion topic: Netflix sky streaming only loading to 20% - switched on and off etc!
This message was authored by: Pricey
Netflix only loading to 20% on films or tv programmes! I've done the usual - switch on and off etc! Broadband all fine and strength great! Don't know what it could be? Any help would be greatly appreciated 👍🏻
Re: Netflix sky streaming only loading to 20% - switched on and off etc!
Hi @Pricey
Open Netflix on your Q box and go the Left hand Netflix menu.
Scroll down to the bottom and then scroll right and select Get help.
On the next screen there is sn option to Reload Netflix.
'Try this.
Avatar for Pricey
Hiya - thanks for replying 👍🏻 tried this and now it's barely loading! I'm in Netflix but show icons are not evening loading! I've run a download speed test and it's 74mbps???? I have got no idea 🙄 I've check network connection and run tests and that's all fine too! I'm baffled 😕
Hi @Pricey
Did you carry out the Download Netflix in the Q box Netflix menu.  (Same screen as the reload option).
Also after reloading Netflix did you reboot the Q box.
