Discussion topic: Recordings disappeared. Turned on TV this evening, nothing in recordings. Have rebooted tv box and .
This message was authored by: And27
Message posted on 02 Sep 2023 10:21 PM
Can anyone help?
Find out more
Message posted on 03 Sep 2023 11:54 AM
Re: Recordings disappeared. Turned on TV this evening, nothing in recordings. Have rebooted tv box a
@And27 wrote:
Can anyone help?
@And27 You could try resetting the settings in the Q boxes hidden menu.
To enter the hidden menu press the home button and scroll down to settings but do not select settings.
With settings highlighted press 0 0 1
Only Carry out the first Reset being Reset Settings as the others will wipe all recordings.
After the reset you will have to re-pair your remote assuming you are using a bluetooth remote by pressing 1 and 3 together on the remote
