Discussion topic: Recording/veiwing options
Message posted on 18 Oct 2024 07:37 PM
Just upgraded to SKY Q and cannot find the user defined function where you can choose which point in time you want to start viewing a recording,,( rather than fast forwarding which is cumbersome) Used this a lot when we had SKY+ HD. Surely this must still be available.!
Message posted on 18 Oct 2024 07:44 PM - last edited: 18 Oct 2024 07:49 PM
Re: Recording/veiwing options
Use the voice option. Press and hold in the voice button and say "go to xx minutes".
There are no reminders bookmarks or slow motion replays.
Message posted on 18 Oct 2024 07:54 PM - last edited: 18 Oct 2024 08:12 PM
As @Daniel0210 says voice control is your friend here
I find handy controls are :
Skip nn minutes
Go To nn minutes
Back nn minutes
You can use hours, minutes & seconds or mix e.g. Go to 1hour 15 minutes
Skip nn minutes is very handy for adverts and you get used to the length on regular used channels (Many are around the 4 minute mark)
You can also say Go To Start
Voice control in general is very useful - see
https://www.sky.com/help/articles/sky-q-voice-control-commands
BTW pressing the FF (or Rewind) key & holding it down also engages a very fast skip
Edit - Correction - For high speed forward / rewind press Pause or other button (e.g. up arrow) to bring up Time status bar then press & hold right arrow (or left arrow)
(I think you can tell, I use voice control instead)
Message posted on 20 Oct 2024 12:13 AM - last edited: 20 Oct 2024 12:21 AM
Also note in addition to the 2 responses above,
Is the option you are looking for is to set how long before and after a programme starts and end, that your recording starts and finishes.
So if you set it at 3 minutes before and after, an hour long programme starting at 9pm would record from 8:57 to 10:03.
Unfortunately this option is not available on sky q.
Recordings start 60-90 seconds before the schedule and end 90 seconds after the scheduled end.
Sometimes (with bbc particularly), it may be good to record the next programme too.
ROI sky Q Customer.
