Discussion topic: Recording series, records same episodes on multiple channels
This message was authored by: Rslevin
Message posted on 25 Oct 2023 10:27 PM
Hi,
I record programs like Coronation Street and EastEnders. However when I select record series, the same episode is recorded on multiple channels, normal channel, HD channel and +1 Channel. Which results in 3 recordings per episode.
Any suggestions?
Find out more
Message posted on 26 Oct 2023 05:29 AM
Re: Recording series, records same episodes on multiple channels
Go into Scheduled Recordings, scroll down to the episodes you don't want, scroll across and cancel the series link tab then cancel the scheduled recording. Do that for the +1 channel and SD channel and it should just leave you with the hd recordings set up.
