Discussion topic: Recording issues
This message was authored by: Hockeyplayer
Recording issues
We have just replaced our 2 multi room boxes for 2 sky Q they both record the identical programs on each box is this normal?
Re: Recording issues
@Hockeyplayer
Yes. Only the main Sky Q box records programmes and they are available on all your mini boxes (apart from UHD content).
hi @Hockeyplayer
SKY Q works quite different to the old separate multiroom option for SKY HD
All recordings are made and stored on the main box & are accessible to every box - except UHD recordings which can only be watched on the main box.
Unfortinately there is no User profile system to separate recordings etc
Avatar for Hockeyplayer
So I suppose I did t need 2 Q boxes then one main box and a mini box??
A  mini box is still SKY Q & this is what you will have as you cannot have 2 main boxes
The mini box acts as a media client to the main SKY Q box which acts as a Media server to the minis
The Minis do, otherwise work independently being able to watch the same or completely different channels or recordings
Presumably they look noticeably different?
Sky Community Forum SuperUser
Former Sky+HD Beta Tester
I've been and idiot, they are 2 different boxes just didn't realise how it all worked, thanks for the help
