Discussion topic: Recording issues
Message posted on 31 Jul 2023 02:49 PM
Recording issues
We have just replaced our 2 multi room boxes for 2 sky Q they both record the identical programs on each box is this normal?
Message posted on 31 Jul 2023 02:52 PM
Re: Recording issues
Yes. Only the main Sky Q box records programmes and they are available on all your mini boxes (apart from UHD content).
Message posted on 31 Jul 2023 03:09 PM
SKY Q works quite different to the old separate multiroom option for SKY HD
All recordings are made and stored on the main box & are accessible to every box - except UHD recordings which can only be watched on the main box.
Unfortinately there is no User profile system to separate recordings etc
Message posted on 31 Jul 2023 05:09 PM
So I suppose I did t need 2 Q boxes then one main box and a mini box??
Message posted on 31 Jul 2023 05:17 PM - last edited: 31 Jul 2023 05:20 PM
A mini box is still SKY Q & this is what you will have as you cannot have 2 main boxes
The mini box acts as a media client to the main SKY Q box which acts as a Media server to the minis
The Minis do, otherwise work independently being able to watch the same or completely different channels or recordings
Message posted on 31 Jul 2023 05:32 PM
@Hockeyplayer wrote:So I suppose I did t need 2 Q boxes then one main box and a mini box??
Presumably they look noticeably different?
Sky Community Forum SuperUser
Former Sky+HD Beta Tester
Message posted on 31 Jul 2023 05:37 PM
I've been and idiot, they are 2 different boxes just didn't realise how it all worked, thanks for the help
