Discussion topic: Record
This message was authored by: G1WXC
Record
Record seems to start with out us doing anything and we can't switch it off
Re: Record
@G1WXC
What is recording? Could it be a programme/series you've previously set up as Series Link and a new series has started?
▪️I AM NOT A SKY EMPLOYEE ▪️
Avatar for G1WXC
Re: Record
We've not set it to record anything
Re: Record
@G1WXC
Is it a new main Sky Q box by any chance?
Also, are there any more episodes of that programme listed in your scheduled recordings that need a) the series link removed then b) the scheduled recording deleted?
Avatar for G1WXC
Re: Record
It's now switched its self off with out use doing anything
Re: Record
@G1WXC
If it stays connected long enough try rebooting the main box:-
1 - Using the Sky Q remote put the box into standby
2 - switch the box off at the plug
3 - wait at least 30 seconds
4 - switch back on at the plug
5 - follow the on-screen instructions
6 - when the screen goes black and the blue ‘Q’ stop pulsating wait another 30 seconds
7 - press the 🏠 button
Avatar for G1WXC
Re: Record
Yes it's new set up by there engineer
Avatar for G1WXC
Re: Record
Ok I'll try that hopefully we won't loose everything
