Discussion topic: Reconditions for mesh WiFi
Message posted on 19 Jan 2024 09:00 PM
Can anyone recommend a solid mesh WiFi system that work seamlessly with sky Q set up with two sky Q mini boxes? I used to have a linksys velop system but had constant issues with the sky Q mini boxes not connecting to the main box. Thanks in advance of any advice.
Message posted on 19 Jan 2024 09:04 PM
							Re: Reconditions for mesh WiFi
The short answer seems to be none of them do. But if you can wire each box into a point it works. I'm using tp link Deco with each box wired to 1 of the decos.
The problem is, your sky boxes may not be positioned somewhere that matches your mesh point placements.
But again the short answer is sky uses its own mesh to connect the boxes unless they are wired - and the whole particular process that goes with getting wired to kick in correctly.
Message posted on 19 Jan 2024 09:25 PM
Thought as much, a lot of comments on here about having to connect via Ethernet if not using skys router.
ive been looking at the deco m5's or the eero systems, just typically struggling to make sure all the child nodes have Ethernet ports, so many of them don't
