Discussion topic: Reclaim my tv remote
Message posted on 10 Jan 2026 10:54 AM
Since getting SKY Q, I can't access any settings on my LG TV, to access sound outputs, Bluetooth etc. I've followed in line advice about going into settings but the options they say to choose just aren't there. Half the advice says change my tv settings but I can't access my tv settings!
Message posted on 10 Jan 2026 10:57 AM
Re: Reclaim my tv remote
You are using the TV remote aren't you?
Message posted on 10 Jan 2026 12:40 PM - last edited: 10 Jan 2026 12:41 PM
A paired Q remote is intended to access television volume and power only. Whether other television settings are available or not is pretty much random: as @Daniel0210 indicates you need the television remote to reliably get to those (and pairing the Q handset has no impact on the functionality of the television remote)
