Discussion topic: Reboot sky q box
This message was authored by: Stevop
Reboot sky q box
This seems to happening more and more frequently now. Come down in the morning and my Sky Q box is stuck with the blue light going round. Only way to solve it is to turn power off and on and restart the box It Is now doing this 2-3 times a week. Any ideas ?
Re: Reboot sky q box
Hi @Stevop Try changing your SKYQ box standby mode from ECO to either Active or Off?
To change your standby settings:
Press Home on your Sky Q remote and select Settings, then Setup.
Select Preferences, followed by Standby mode and select the setting you want.
Avatar for Stevop
Just checked and the box is already set to Active.
Hi @Stevop
This message was authored by: Day230965
Had an actual sky engineer to check problems on sky q box.
He said no problems then next day problem still there.
I have MS so spend all day watching tv then Sky Q breaks!
what can I do?
I have it all insured tho cannot come back til 10/12/24
disgusting service
Devastated & bored with immense pain.
what can I do?
disgusting service
@Day230965 what problems are you having with your Q box ?
