Discussion topic: Mini box connection
This message was authored by: TheHoffs
Mini box connection
My husband got up last night to watch the fight and found that the wifi had dropped, he reset it and watched the fight. Main box all ok but none of the mini boxes are working. Have tried everything, network connection, connect to main box, rebooted etc etc. Nothing is working!
Re: Mini box connection
Hi @TheHoffs
Assume you tried the complete following procedure?
Reboot the minis as above.
If you are on Sky Broadband and the Router is nearer to the mini than the main box then you can try pressing WPS on the router instead of the main Q box. If you do this make sure you press the Sky router WPS button and not the router reset button. If you get the first mini connected then for other minis use WPS on the nearest Q device (main Q box or Sky Router if on Sky Broadband or previously connected mini).
Avatar for TheHoffs
Yep, tried everything that normally works but they are not having any of it. Tried the Tech Helpline which directed me here but the only suggestions that come up as a match are all the things I have already done so I thought I'd post the question
