Discussion topic: Re: TV issue
This message was authored by: Rash2
Re: TV issue
Hi my sky is saying no signal why is this
Re: TV issue
@Rash2
I've moved your post to a separate thread as it's not connected to the issue the original OP had. A message displaying ”no signal” tends to be generated from your TV and normally means your TV’s not seeing the Sky box on the relevant HDMI input.
If a message displays “no satellite signal” firstly check that the connections from the Sky dish going into the back of your Sky Q box are still finger tight. Otherwise it’s likely to be a dish alignment issue so check the troubleshooting in this link
If you are connected to a communal dish you need to liaise with your building management company / landlord who will have their approved engineers to contact.
Remember, a misalignment is not necessarily something that will be visible to the naked eye and could only affect one or two channels.
