Discussion topic: Re: Sky Q box failure
This message was authored by: DDat1
I pay over £60 a month  via direct debiit with faullty equipment provided by SKY . I keep losing Hard drive issues . Phone line keeps telling i ringing at busy time. Online worse i cannot help. I have VIRGIN super fast Internet better than SKY. I  want cancel because of there very poor equipment provided by them it does NOT work
@DDat1
Try following this link. It should lead to a replacement box if needed https://www.sky.com/help/articles/sky-q-hard-drive-errors
If you do need a new box remember to remove the viewing card from the faulty box before it disappears into the back of the couriers van and accept any new power cable DPD deliver with the replacement box in case it's different to the one you have.
▪️I AM NOT A SKY EMPLOYEE ▪️
@DDat1   To cancel all your TV subscription, if you’re out of contract you’ll need to give Sky the required 31 days notice. The latest T’s and C’s explicitly state you can’t cancel when still in a minimum term deal unless Sky agree. If they agree you’ll have to pay the remainder of your discounted term.
Select ‘Need more help’ at the bottom of the following link which will lead to contact details.
https://www.sky.com/help/articles/cancel-sky-tv#contact-leave
(Make sure the flag in the bottom right corner is the correct one ie; UK or ROI).
UK customer ~ The link may include an email link and also a Message Us option (which is normally available between 9am and 7.30pm).
ROI customer ~ it’s only by calling Sky Ireland or writing in.
If you successfully cancel you should receive an acknowledgment email from Sky.
If you are cancelling Sky Q, return packaging will be sent out near the end of your notice period. It’s important that you obtain proof of posting and keep it safe and indefinitely.
If you’re moving to another ISP you could use the One Touch Switching system which is explained in this link
https://www.uswitch.com/broadband/guides/one-touch-switch/
If you are cancelling Broadband/Talk altogether you need to contact Sky and give the required notice of 14 days. Remember that if you are still in a discounted 18/24 months deal Sky could impose cancellation charges.
Return packaging for any equipment Sky expect back will be sent out to you near the end of any notice period. Remember to keep any proof of posting indefinitely.
