Discussion topic: Re: Return Sky Equipment Mistake
This message was authored by: Skyiv8hj
Sky q not working on some features I have tried  all recommend  fixing
@Skyiv8hj
I have moved your post into a separate thread as it has no connection to the thread you added to.
You haven't said what features aren't working so try a reboot of the main Sky Q box, then once that’s back up and running do the same with any mini boxes if applicable -
~ press the 🏠 button
Allow 5-10 minutes before things hopefully revert back to normal.
