Discussion topic: Re: Error opening SkyGo on iOS
This message was authored by: Uzo1
My sky mini box is not working
Avatar for Uzo1
  • I have rebooted, bought a new cable still not working
Avatar for Uzo1
Still waiting for a response
Re: Mini box not working
Hi @Uzo1
Reboot the mini as above.
@Uzo1
You haven't received a reply for a few reasons:
Firstly we are customers here who help each other and secondly you added this to a topic where someone was asking about Sky Gon which id a different product.
This has now been moved to the Sky Q forum for you,
@Uzo1  In addition your duplicate thread you created has been removed, if you receive no reply you need to be patient as advised by @caesarome  this is a customer helps customer community.  Creating multiple threads won't get a quicker response.
