Discussion topic: Re: Error opening SkyGo on iOS
Message posted on 01 Mar 2025 11:22 AM
My sky mini box is not working
Message posted on 01 Mar 2025 11:24 AM
- I have rebooted, bought a new cable still not working
Message posted on 01 Mar 2025 11:27 AM
Still waiting for a response
Message posted on 01 Mar 2025 11:36 AM
Re: Mini box not working
Hi @Uzo1
Reboot the mini as above.
Message posted on 01 Mar 2025 01:21 PM
You haven't received a reply for a few reasons:
Firstly we are customers here who help each other and secondly you added this to a topic where someone was asking about Sky Gon which id a different product.
This has now been moved to the Sky Q forum for you,
Message posted on 01 Mar 2025 02:43 PM - last edited: 01 Mar 2025 02:44 PM
@Uzo1 In addition your duplicate thread you created has been removed, if you receive no reply you need to be patient as advised by @caesarome this is a customer helps customer community. Creating multiple threads won't get a quicker response.
