Discussion topic: Re: Connecting surround sound
This message was authored by Andrewp118 This message was authored by: Andrewp118
Can I jump on this thread please! I have a similar problem. I have a soundbar with one hdmi and one optical, a skyq box and a tv with only one available tv hdmi because I have a firestick in the other. It is an e-arc port. Can I set this up so that only one hdmi port is used on tv and soundbar and sky q connect via optical? Sorry, but I have no technical knowledge!
hi @Andrewp118
So as not to confuse the orignal discussion with replies to both I thought it might be better to separate your query into a new discussion.
If you do not need Atmos sound then using an optical cable from the SKY Q box to your Sound bar might be a suitable option for you.
If you can give make & models for both TV & Sound bar and what else besides the Firestick is using any HDMI ports & anything else connected to the Sound bar, we might be able to think of alternatives - although using an optical cable as above might be the simplest for you at this time
Andrewp118
Soundbar/skyq/firestick/tv connection problem
This message was authored by ThePope27 This message was authored by: ThePope27
Re: Soundbar/skyq/firestick/tv connection problem
Is there an optical out on the TV rather than using eARC?
________________________________________________________________________________________
Sky Q 2TB v2 Box + 2 Mini Boxes - Brsk BetterNet1000 FTTP, WatchGuard M400 Firewall, Plume Mesh
Sky Signature + Ultimate TV Pack, Sky Sports, Sky Cinema, Sky Kids, TNT Sports, MUTV, LFCTV, Racing TV, Premier Sports, DAZN
@Andrewp118
I have moved your new post with your existing post.
As per my initial reply, please give us the extra details I asked so we can try to advise
Have you tried an optical cable from SKY Q to Soundbar  that I said should work for you ?
Andrewp118
Thanks for the advice. The optical solution has worked perfectly! Many thanks.
