21
Discussion topic: Random no sound/black screen flicker
This message was authored by Simonb73 This message was authored by: Simonb73
Re: Random no sound/black screen flicker
Just re read and you say you have turned off Deep colour for the HDMI.
this means you are using 8-bit  can you confirm this is the setting you are using?
MrWinn
This message was authored by MrWinn This message was authored by: MrWinn
Sorry it was TV
This message was authored by Samsimmo This message was authored by: Samsimmo
I am having same issue with my brand new g4 with sky Q has anyone found a fix yet?
MrWinn
Yes, reset TV.
i had to do it again recently after TV had a new software update.
When you say reset the tv do you mean back to factory settings and start again or just turn off at the mains and reboot? Cheers.
MrWinn
 factory settings unfortunately, bit of a pain if you have to do it after every software update.
I have recently turn Sky Q box back to 1080p and turned on deep colour on the TV and picture drops outs returned. Back to deep colour off and 1080i on the Sky Q box. Seems to fix it. I did reset the TV too and that sorted the sound drop outs.
