53
This discussion topic has been answered Discussion topic: Radio programme information missing?
This message was authored by: Clem1234
My Sky Q box is no longer showing any programme information for any radio channel, which makes selecting a programme to record very difficult.  According to Sky, programme information for the next seven days should be displayed. Is anyone else having this problem?
Re: Radio programme information missing?
Yep, appears to be fixed.
@Clem1234
Which radio stations? A lot were removed last year as per this thread…
https://helpforum.sky.com/t5/What-s-On/Closure-of-radio-channels-13-12-23/m-p/4508243#M141661
Avatar for Clem1234
Level 4 icon
There is no programme information for any radio station, including BBC
@Clem1234
Post edited. It's the same for me too.
This message was authored by: Doctorbob1
TV guide is not shown any radio programme
The TV guide is not showing any radio programmes I've turned the box off and rebooted it but it's still not showing any radio listings is it the box or something else?
Re: TV guide is not shown any radio programme
@Doctorbob1
I've moved your post into a thread already mentioning this. I haven't checked the epg recently. You could email the Viewer Relations Team at [email protected] if it continues.
This message was authored by: Dippedsoda
I have Sky Go and there is no information in the programme guide for any listed radio station. I have tried switching off/on, checked software downloads, preferences set to "eco". If you select a radio channel you can still find out on screen information about the programme on the channel. This problem started yesterday!
This message was authored by: oracle2018
is anyone unable to get listings for bbc radio 4 extra?
so, I am completely unable to get any listings for bbc radio 4 extra on my sky q box.
this is a recent thing, because I am always recording shows from it (especially comedy club)
if I speak in to the controller the radio 4 show I'm after, it will come up but it won't let me record it
any ideas?
Re: is anyone unable to get listings for bbc radio 4 extra?
any ideas?
@oracle2018 I moved your post into the already thread in regards to this problem as you are not the only one havung this problem
LG 49SJ 810 V UHD TV
Google Pixel 10 Pro XL mobile
This message was authored by: Lelee34
My Radio station listing are not showing up
My Radio listing are not showing up
Re: My Radio station listing are not showing up
@Lelee34 i've moved your post to a larger thread regarding the same problem as you are having
This message was authored by: klou
I have this problem too. Ive reset my box twice but still nothing for the radio cgannels
This message was authored by: Nedder
I have been having the same problem since yesterday. I turned my box off and on, and still no radio listings.
This message was authored by: friendpeter
Re: Radio programme information missing? i have tried switching sky q box off and on no difference
no radio guide for 2 days switched sky q box off and restarted no difference unable to record radio programmes
As this is still an issue this morning I have made Sky Community staff aware on a closed forum. I'll update this thread as and when an update is provided.
