Discussion topic: Qbox failure
This message was authored by: Stuart60
Qbox failure
Sky Q box failing
not recording
not responding to remote control
constant on screen technical fault messages
poor connection to Netflix iPlayer etc screen freezes
have rebooted q box
have rebooted internet hub
has been problem for a while
is getting worse
will not even connect to live tv channels now
'feels like' is a hardware issue
box is in constant use
please help
This message was authored by: Doc5907
Re: Qbox failure
@Stuart60 wrote:
Sky Q box failing
not recording
have rebooted q box
is getting worse
please help
@Stuart60  you could try the following :
Try a Reset Settings in the hidden menu.
Scroll down to Reset
After the Reset you may have to re pair your Bluetooth remote If you use one.
Failing that it's probably time to call Sky for an engineer and possible box replacement.
Sky Q 1TB UHD
LG TV
Sky Mobile
