Discussion topic: Want to cancel tent sports with out having to phone up
This message was authored by: nickbradders
How can i cancel TNT sports with out phoning ... is there anyone i can message?
Re: Want to cancel tent sports with out having to phone up
@nickbradders  If you subscribe through Sky You will need to call Sky or use the following link https://www.sky.com/help/articles/cancel-sky-tv#contact-leave
On the link provided (In the UK) it should include a Message Us option between 0900-1930.
You can also call on 150 from a Sky Mobile or Sky Talk line
(UK) https://www.sky.com/help/home Scroll down and click on ‘Need more help’ and it provides a 0333 number
(ROI) on the same link change the flag in the very bottom corner to the ROI flag to obtain an 0818 number.
Stay on the line and don’t hang up if prompted to. Apparently the quieter times to ring are just after 7am or about 9pm.
If you don't see the Contact options on the link above make sure java script is enabled on your browser.
This message was authored by: best+of+the+best
@nickbradders if it's through Sky then you have to ring I'm afraid I've got mine through BT.com and I can cancel anytime via MyBT
