Discussion topic: Qbox cable connectors
This message was authored by: Richard+Skeoch
I want to shorten my cable, But I can't get a connctor to fit the cable. my cable says car63 dual 250 caracal 060 meter.
but the connectors i've bought are wrong size. Either the inner shieth hole is too big or the plug won't go over the outer plastic or won't crimp. Has anyone any suggestions please?
This message was authored by: Me134
Re: Qbox cable connectors
That's the satellite twin coax cable is it not? You're looking for Coax F screw on RG6 plugs.
Not a Sky employee
Sky FTTP 500Mb to Max Hub (WiFi disabled)
Pair of TP-Link Deco BE65's in AP mode used for WiFi access, main Deco hardwired to Max hub
2 Windows desktop PC's hardwired to each Deco, everything else using the Deco WiFi
@Richard+Skeoch  @Me134
I believe a standard F connector won't necessarily fit an individual strand of 'mini-shotgun' cable.
@Godfrey may be able to advise.
hi @Richard+Skeoch
I think SKY use WF65 or similar - so if you search for F-Connectors for WF65, I think you should be OK.
RG6 is closer to the  thicker WF100 which SKY don't use for most installs
Spot on for both points 🙂
"screw on f connector for CT63 WF65 coaxial cable"
https://helpforum.sky.com/t5/Sky-Q/Aerial-adapters/m-p/4302921/highlight/true#M577258
Not a Sky employee
hi @Richard+Skeoch
Yes, apparently the RG6 are only used for particularly long runs of the thicker coax cable. My bad.
Not a Sky employee
