Discussion topic: Q remote switches off air conditioning
Message posted on 01 Jul 2023 09:05 PM
I have a BROLIN aircon unit and every time I use my Q handset it switches off my aircon. Can I change the settings on handset.
Message posted on 01 Jul 2023 09:14 PM
Re: Q remote switches off air conditioning
There's no user access to any infra red settings, which is presumably the issue. If your Q box is using Bluetooth, personally I'd try something like electrical or masking tape over the end of the remote as an experiment.
Message posted on 02 Jul 2023 12:03 AM
it seems to be the handset that only works on bluetooth. I rebooted it and it's ok now on that one but I have reprogram the main set Eleuthera voice. Will let you know
