Discussion topic: Q remote randomly turns on both box and tv
This message was authored by: NMF26
Have set up the remote to turn on tv at same time as Q box, but it only works every now and then. Anyone else have this problem?
TV is LG OLED55 B8
TIA
This message was authored by: cbball
Re: Q remote randomly turns on both box and tv
Not the same TV as you, but mine works like this:
Handset ON/OFF button
1.  Short press turns on QBox and TV
2. Another short prss, once they are on, turns off Q Box.
3. A longer press then turns off TV.
Took the wife sometime to tell the difference from a short ptess and a long press.
