Discussion topic: Q remote control issue
Message posted on
15 Mar 2023
09:18 AM
- last edited:
15 Mar 2023
09:29 AM
by
Kirsty+S27
Sky q remote voice control doesn't switch on comes up no signal have to press really hard same thing when switching off
Moderator comments: edited title to include the remote control issue
Message posted on 15 Mar 2023 09:37 AM
Re: Q remote control issue
If you are trying to switch your Q box on by Voice control then this is not possible .
The Q box needs to be already on to accept Voice commands.
Message posted on 15 Mar 2023 09:42 AM
Re: remote control issue
Sorry miss understanding the problem is turning the television on with the remote the engineer said say 123 and it comes on doesn't work have to press remote control button really hard and that doesn't always work
Message posted on 15 Mar 2023 09:50 AM
No such command as 123 I'm afraid. No voice commands will operate the television; only the Q boxes
The Television can be switched on in two ways with the Q remote.
First is by HDMI control which must be turned on in the Q box and also the television settings.
Second way to turn Television On or Off is with a long (3 second) press on the Q remote Standby button provided the Television is correct paired with the Q remote. If it is paired you should find that the Q remote will adjust the volume on your television.
