Discussion topic: Q mini box - Not able to connect to activation server
This message was authored by: Garethshughes00
Sky q mini hub - I keep getting the error message that it’s not able to connect to the activation server.  Switching on and off doesn't help.  Internet is fine for everything rise including other apps on the tv
Re: Q mini box - Not able to connect to activation server
Hi @Garethshughes00
Reboot the mini as above.
