4
This discussion topic has been answered Discussion topic: Q box
This message was authored by: andysbro
Q box
Started a new free upgrade to fibre , so a openreach engineer came to the house , he installed everything he could on the inside , but could connect due to another contractor having to connect to the external of the house . So he left the old router working so we could watch tv and have internet connection. The new router was connected but not properly working due to other contractor . The SKY Q BOX has lost its saved recordings and I can't record anything.  Can anyone help
This message was authored by: PandJ2020 Answer
Re: Q box
Changing the ISP would have no direct impact on the Q (Where the primary source is satellite dish).
Sounds like your hard drive has failed?  https://www.sky.com/help/articles/sky-q-hard-drive-errors
Re: Q box
Re: Q box
Turn the new router off
Avatar for andysbro
Re: Q box
Tried that never worked, also turn tv from the wall , still no luck . Followed sky instructions to reset the hard drive , no luck. So sky going to send me out a new box
Avatar for andysbro
Re: Q box
Thanks for your help , yes the hard drive did fail
