Discussion topic: Q box
Message posted on 02 Oct 2023 08:55 PM
Q box
Lost connection to my q boxes but the main box is fine? Had issues with locking screen on the w boxes??
Message posted on 02 Oct 2023 09:12 PM
Re: Q box
@Sauna+Dave Have you tried rebooting your main Q box ie
then
reboot your mini box
Re: Q box
Hi @Sauna+Dave
Assume this is an issue with your mini boxes.
Reboot the mini as above.
