Discussion topic: Just got a new sky Q box and I can’t control volume or signal with the remote when I try and set it
Message posted on 02 Oct 2023 09:16 PM
I can't control tv volume or signal using the sky remote but when I'm trying to set up the remote to be able to o just get stuck on a pleade wait screen infinitely. I have a JVC tv and have just got the sky box around 12 o'clock. What should I do?
Message posted on 02 Oct 2023 09:23 PM
Re: Just got a new sky Q box and I can’t control volume or signal with the remote when I try and set
First reboot your Q box.
Then Try completly resetting your Bluetooth remote.
