Discussion topic: Q box remote control Input Source Control button. I pressed by mistake & don’t know how to cancel it
This message was authored by: Marybr
The recording that I was watching disappeared (black screen) and the TV was broadcasting a radio programme called TalkSport. The volume buttons were working.
Re: Q box remote control Input Source Control button. I pressed by mistake & don’t know how to c
Hi @Marybr
Press the input button slowly multiple times and it should cycle through all the inputs on your TV set.
Stop when you get back to the Sky Q picture
This message was authored by: William288
I don't think there is a way to use the sky Q box remote control as I can cycle through the various input sources using the top right button but pressing the ok button doesn't select and change to the desired source. As I don't have my tv remote anymore I have to do it manually with the buttons at the lower right on my tv.
  • Useless sky boxes are...
Most TV's will automatically select the input as you cycle though.  For me, it will automatically select after a short pause.
The remote was only ever designed to send volume, power and AV functions if correctly configured.
Yeah it cycles for me automatically. I don't have to hit enter
If it didn't on my TV, I'd buy another remote for the TV.
