3
This discussion topic has been answered Discussion topic: Input source
This message was authored by: john.m18
Input source
Why doesn't my input source button work on my sky q  remote
Re: Input source
Hi @john.m18
Does your Q remote alter your TV volume and also switch your Television Onand Off using a long (3 second) press?
Re: Input source
Hi @john.m18
This message was authored by: William288
Re: Input source
Yes mine does but it doesn't change the input source.
Re: Input source
Might have picked a close but not exact match for the TV model. Unusual for them not to use the same IR codes if they do use the same for volume & power though.
