Discussion topic: Q box not working
Message posted on 09 Jun 2023 10:49 AM
Q box not working
My Sky box isn't working.
Message posted on 09 Jun 2023 10:56 AM
Re: Q box not working
We'll need a lot more info in order to help you.
What is happening? What error message, if any, are you seeing? What have you already tried?
Message posted on 09 Jun 2023 11:10 AM
Hi @Dalvindo
Assume you have tried rebooting your Q Box.
Wait for the on screen instructions to disappear and the front led to turn Amber. Then wait for 30 secs before you press Home on your Sky Q remote or if this is not working press the standby button on the front of the Q box (Amber led).
If the remote didn't switch the box on
Try completly resetting your Bluetooth remote.
Then make sure that you are pointing your remote at the Q box and press 1 & 3 together until the led flashes and follow onscreen instructions to re- pair.
