Discussion topic: Q box not working
This message was authored by: Karen1211
Message posted on 28 Aug 2024 05:33 PM
Q box not working
Sky Q box not working properly, not recording at all
Find out more
Message posted on 28 Aug 2024 05:40 PM
Re: Q box not working
Have you worked through the steps here?
sky Q | sky Mobile | EE Full Works FTTC | LG B6 OLED | SONOS Beam 2
Find out more
LG 49SJ 810 V UHD TV
Google Pixel 10 Pro XL mobile
@Karen1211 wrote:
Sky Q box not workin@g properly, not recording at all
@Karen1211 Have you tried rebooting your main Q box ie
