Discussion topic: Q box not connecting to internet
This message was authored by: Denise40
My WiFi connection appears to be working. I can connect on my phone. However my sky q is not able to connect. It says unsuccessful connection. It has been working fine until today.
Re: Q box not connecting to internet
Hi @Denise40
Highlight Status and then select Reset on the right hand side. Follow instructions to connect by WiFi to your router. Even if reset is not listed there is still an option to connect by WiFi to Sky or 3rd party router.
If you are on Sky Broadband with the new Sky Max router then you need to connect it as if it is a 3rd party router.
If you are on 3rd party (non Sky ) broadband then you need to enter the SSID and password for the router 2.4 Ghz WiFi band.
Avatar for Denise40
Thank you very much. I've tried the reset and it just ends in connection unsuccessful. I've also done complete power down. All my devices, phone, tv and laptop are connecting. My sky q tv is fine but no internet connection to the sky q box.
I've tried all the various suggestions from sky and none of the options explicitly describe my problem. I can't seem to find any way to get through to sky to speak to someone. Any ideas please?
Who is your Broadband supplier @Denise40
and where is your Q box located in relation to your router?
Avatar for Denise40
Broadband is with Sky. The router is right next to the sky box. Thanks
Best thing to do then @Denise40 is to connect the Q box to the router by Ethernet.
If you have no minis then you can switch the Q box WiFi Off.
On the Q box carry out a Network reset with the Ethernet connected.
Highlight Status and then select Reset on the right hand side. Select connect wired to non Sky Router (or Sky router if on Sky Broadband). Do not carry out any WPS and just wait for the box to connect. It may take a couple of minutes. If it does not connect there is an issue with the Ethernet connection.
As soon as it connects go immediately into the Q box hidden menu and turn off WiFi.
Go to Network to turn off both bands of WiFi. Confirm before exit.
