Discussion topic: Q box installed and now broadband not working consistently with buffering on apps every few seconds
Message posted on 20 Dec 2024 06:36 PM
Q box installed this week and now cannot use iplayer as buffers every few seconds. Can see from searches this is not a unique problem but what is the solution? We have Vodafone broadband routet
Message posted on 20 Dec 2024 06:45 PM
Re: Q box installed and now broadband not working consistently with buffering on apps every few sec
Hi @AlanP1
Try completly resetting your connection.
On 3rd party broadband and your router does not have a reset button, reboot it by disconnecting the power lead for 30 secs and then reconnecting.
On 3rd party (non Sky ) broadband then you need to enter the SSID and password for the router 2.4 Ghz WiFi band.
Once your Q box is connected to the internet try a Reset Settings in the main Q box hidden menu.
