Discussion topic: Q box dropping off the wifi.
This message was authored by: LukeB
Box was on the wifi when it was set up. Worked fine for a week or 2, then dropped and had to be reconnected.
Now its dropped and won't reconnect. This happened shortly before I cancelled by sub a while back but I assumed it was due to the box being old, this is a brand new box.
Re: Q box dropping off the wifi.
Hi @LukeB
Are you carrying out a Network reset exactly as follows?
Highlight Status and then select Reset on the right hand side. Follow instructions to connect by WiFi to your router.
Avatar for LukeB
Hi @oldfella
Yes I've done all that. After 5 more attempts it has now connected again, but I have no doubt it will kick me off again.
I'll see how it goes. Just a tedious waste of time having to keep redoing it
