Discussion topic: Q Box stuck in reboot
This message was authored by ChrisFrankum This message was authored by: ChrisFrankum
After unplugging from the mains for 10 minutes my Q box is now stuck still on "You will be ready in a couple of minutes" for over an hour now with the fan or hard drive whirring
Re: Q Box stuck in reboot
Hi @ChrisFrankum
https://www.sky.com/help/articles/sky-q-box-wont-turn-on
Also if the box you are replacing is a 2TB there are two versions of power supply. One has a standard C7 (figure of eight) power lead socket in the back of the Q box. The other has a separate power supply. Although this still has the C7 power lead into the power supply there is a multi pin Din power socket in the Q box for connecting the power supply. Make sure that the replacement box has the power supply included if the Q box has the orange coded multi pin din socket in the back of the Q box. See below.
