This discussion topic has been answered Discussion topic: Q Box disconnecting from Broadband
Message posted on 13 Apr 2025 12:32 PM - last edited: 13 Apr 2025 12:35 PM
Good morning all.
Wondering if anybody has any suggestions please.
We have Sky Full Fibre Gigafast and Sky Q and both have played nicely together since the fibre was installed last year, but, since the recent outage that affected Devon & Cornwall (may be pure coincidence) the Q box drops the network connection 2 or 3 times a night. Reconnect via the WPS and it may stay online for an nour or so, then knocks off again, as it's the other half who watches the programmes on the apps via Q, I am getting a large amount of larrup about why. Wifi signal to devices futher away are in the 400-500 MBPS range so don't think that's an issue, and as said, it was working fine.
Any bright ideas to stop me getting earache gratefully recieved 🙂
Message posted on 20 Apr 2025 06:33 PM
@homerbronco wrote:Thanks @Chrisee there are no Sky Mini's and the Mx hub has no WPS, everything else in the home is connected robustly to the wifi (ither the Max hub or router) with no issues, only the Q box keeps dropping the connection, to be honest I have set up madams apps on the TV this morning so she can watch what she needs, the TV stays connectec fine so it points (in my mind) to an Issue with the Q box, but will pick that up with Sky sometime
Well yes there is a massive issue with the Q box and non-old-school Sky routers.
You might get somewhere with the password approach but I suspect it will be flakey.
Message posted on 13 Apr 2025 12:51 PM
							Re: Q Box disconnecting from Broadband
Can you connect the sky q box to the hub with an ethernet cable ?
Message posted on 13 Apr 2025 02:24 PM
Unfortunately not due to distance
regards
Steve
Message posted on 13 Apr 2025 04:10 PM
@homerbronco wrote:
Good morning all.
Hi @homerbronco
just be aware that if you have the latest Sky Max broadband router then you need to connect it to your Q box as if it was a 3rd party router.
Try completing the following:-
Highlight Status and then select Reset on the right hand side. Follow instructions to connect by WiFi to your router. Even if reset is not listed there is still an option to connect by WiFi to Sky or 3rd party router.
On Sky Broadband you will be asked to press the WPS button on the Sky router. (Not on the Q box as the Network reset will start the main Q box WPS automatically). Make sure you press the WPS button on the Sky router and not the reset button.
If you are on Sky Broadband with the new Sky Max router then you need to connect it as if it is a 3rd party router and you need to enter the SSID and password for the router 2.4 Ghz WiFi band.
Message posted on 18 Apr 2025 01:43 PM
Hi @oldfella thank you for the comprehensive reply.
Managed to follow your instructions last evening but alas the issue remains, also wonder why it would require any change to any settings ( Q box or router) when it used to connect without issue and as far as I know, nothing has changed.
Will have to get onto Sky, but thanks again for your suggestions
Steve
Message posted on 18 Apr 2025 07:24 PM
Have you got any minis?
Message posted on 18 Apr 2025 07:54 PM
Hi @Chodley
No Mini's, have a Sky Booster about 10 foot from the Q Box, same physical location has a Ps5 connected with Network speeds around 450Mbps and solid, so can't think it is a signal issue as such, given the fact it's somethnig that started randomly and has progressively got worse, my gut feel is an issue with the Q box? There are a lot of devices connected to the router via Wi-Fi but further away than the Q box and all work fine.
Thanks for the reply
Steve
Message posted on 18 Apr 2025 11:57 PM
Yeah that's typical. It's never the wifi.
Why is the booster near the Q? You need it somewhere the Q can reach it but where it can get a very good signal (or better yet ethernet connection) from the router.
I'm assuming this is specifically a Q booster?
Message posted on 19 Apr 2025 12:02 AM
Also is it possible a neighbour has added a new network on the same channel as yours?
Message posted on 19 Apr 2025 10:25 AM
Hi @Chodley
Yes it's a Sky Booster, it's not in place specifically for the Q box, but for laptops situated about 15 foot further on from the Q box away from where the hub was installed (totally wrong place but long story) & can't see any sign of other network, being fair where we are there are very few other homes using BB.
Cheers
Steve
Message posted on 20 Apr 2025 07:41 AM
Ok so that's not a Q booster I don't think. But as you have Sky BB it should work the same way
And you are using the WPS button on that and not the router, presumably?
Message posted on 20 Apr 2025 08:38 AM
Are you talking about a a Sky Max pod, that you are calling your Sky booster?
Message posted on 20 Apr 2025 09:00 AM
Hi @lettice & @Chodley  my fault, and terminology, it's a Sky Max pod (with no WPS) we have.
Have tried connecting the Q box again to the Wifi this morning but it kicks off as soon as set up complete each time. Looking through the list of devices in the app, the only one which I don't recognise is called "BskyB Ltd-A336 which it says is connected but if that is the Q box, isn't.
Thanks for the replies both.
Message posted on 20 Apr 2025 09:25 AM
Any ideas on this Sky Max router and Sky pod causing an issue from a recent downtime of the fibre connection here with the Sky Q setup.
Message posted on 20 Apr 2025 11:37 AM
@homerbronco & @lettice do not use the wps function to try and connect the main Q box to a white Wifi Max hub and pod combination instead enter the pasword as you would for a third party router. This advice appears to be what Sky engineers are now giving.
Assume yoy are aware any Sky Q minis have to be networked to the main Q box NOT directly to the white hubs.
